Author Topic: Removing Protected Text  (Read 5686 times)
Sean Gifford
« on: October 05, 2012, 08:11:39 am »
I'm trying to modify copies of some of the system templates, and frequently run into cases where I am not allowed to delete protected text.  How do I delete this?
Thanks!
Ronaldo Juliatto
Re: Removing Protected Text
« Reply #1 on: October 05, 2012, 12:12:41 pm »
Hi, Sean
Usually this error happens when you are trying to remove some of the sections (the yellow-marked text in the template). You can remove them by unchecking the respective element in the window "Sections" (usually located at left of the main window of the designer), where you define which elements are included in your report.
Ronaldo
Sean Gifford
« Reply #2 on: October 06, 2012, 01:57:41 am »
That's exactly what it was, of course, must've been sleeping.
Thanks!
