Author Topic: Interaction Occurance link to diagram broken  (Read 3316 times)
fouchke
« on: October 09, 2012, 08:44:25 pm »
In my current model I’ve setup a view sequence diagrams which refer to sub-sequence diagrams. I have done this by dragging the sub-sequence diagrams into the main sequence diagram to create Interaction Occurances of the sub-sequences. These interaction occurances are normally linked to the sub-sequence diagram, so when you double-click them the actual sub-diagram will be opened.
Regretfully some of the links are not working anymore. I am using SVN as the version control tool. So, maybe the broken connections are cause by the check-in mechanism when the link are crosspackage-links.
Anyway, can someone tell me how to repair the links from an Interaction Occurance to the actual diagram?
Re: Interaction Occurance link to diagram broken
« Reply #1 on: October 10, 2012, 11:28:56 pm »
I remember having had this issue a year or more ago. I (think that I) reported a bug but it seems to be still present. I circumvented it by some tricky automation restoring the links. Sorry for not being able to post the solution as it has been done for a past customer.
In your case you should send a bug report.
fouchke
« Reply #2 on: October 11, 2012, 06:17:08 pm »
qwerty,
thx, i will submit a bug report.
you probably restored the links in the XML files manually or with a script. I was thinking of doing that, but was hoping that there was a easier solution.
fouchke
« Reply #3 on: October 11, 2012, 06:19:58 pm »
qwerty,
just one question: where can I submit an bug report?
« Reply #4 on: October 11, 2012, 11:20:53 pm »
Bottom right in the Support column :-)
fouchke
« Reply #5 on: October 12, 2012, 04:35:49 pm »
i looked everywhere except below  :-/
thx
