Author Topic: DoDAF OV-3 and SV-6 Help  (Read 4686 times)
kimberly
« on: October 09, 2012, 04:47:39 am »
I am using the DoDAF module and have created a project using that template/pattern.  The OV-3 and SV-6 have "table" diagrams in their folders, however, I can't find any documentation on the table diagram.
I also don't see how to automatically generate either of these views from the information entered in say, the OV-2 (for the OV-3).
Thanks for any help!!!
Dermot
Re: DoDAF OV-3 and SV-6 Help
« Reply #1 on: October 09, 2012, 02:48:29 pm »
Both OV-3 and SV-6 are implemented as Search queries. I sugest you try a Ctrl+F and look at the set of Searches under the UPDM 2.0 search group.
P.s. there is a draft paper on UPDM covering these views - as it is yet to be published you can contact support via email (see below) and I will pass it on.
« Last Edit: October 09, 2012, 02:53:28 pm by Dermot »
kimberly
« Reply #2 on: October 10, 2012, 02:24:50 am »
Thanks.  How do you add the necessary attributes for the diagrams?  The OV-3 and SV-6 tables have a required set of data we have to provide.  I haven't found the attributes in the Search or the Table views in EA, and it's unclear how I add the required information.  thanks again!
doneill
« Reply #3 on: October 13, 2012, 06:23:40 am »
I'm curious about this as well.  Below is some feedback I heard from [email protected]:
With the OV-3 search query - this is locked for modification, however you can copy the SQL text from this and create your own OV-3 SQL query and add any fields you want within the scope of the SQL statements.
For more details on setting these up see:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/navigate_search_and_trace/creating_filters.html
