Author Topic: Consistent use of ports on blocks and parts  (Read 3712 times)
mike08
« on: October 18, 2012, 12:15:41 am »
Hi all,
I'm working on a SysML design within I use BDDs and IBDs. I've created a block "House" including a number of ports to be re-used. When now creating IBDs I drag the House block onto the IBD to create a part myhouse:House.
However, this instance does not include any of the created ports.
How can I use EA to visualize/access and use the ports of the underlying block in the derived part? Or (equivalently) how can I assign any newly created port in the part back to the original block for further use in other contexts?
Mike
MMA
Re: Consistent use of ports on blocks and parts
« Reply #1 on: October 18, 2012, 01:56:17 pm »
In EA 935, you can Ctrl + Drag the block with ports (element House) on an IBD diagram, then the "Paste Element" will prompt.
1. Select "as Property of Element(SysML 1.2::Property")
2. Check "Inlucde Embedded Elements" | Select "All Embedded Elements"
OK
Then a property typed by House will be created. This property have a port on it.
You can also show/hide the embedded elements by: context menu on the property | Embedded Elements | Embedded Elements | Check "Show Owned/Inherited" | All | Close
Cheers
mike08
« Reply #2 on: October 18, 2012, 03:29:22 pm »
Thanks, that exactly did the job!
Best regards,
Mike
