Author Topic: Generating several types in single header  (Read 4234 times)
slerp
« on: October 17, 2012, 09:39:39 pm »
Hi all,
I'm using EA to generate C-src.
Now the "problem" ist that for every single typedef a header is generated.
Is it possible to specify an artefact for several types in a way that these type are located in one single header?
now:
ADC_test.h
 typedef struct {} ADC_test;
PWM_test.h
 typedef struct {} PWM_test;
wanted:
test.h
I looked arround but did not find any solution for this.
Kind regards & thank you
slerp
« Last Edit: October 17, 2012, 10:03:33 pm by slerp »
Helmut Ortmann
Re: Generating several types in single header
« Reply #1 on: October 18, 2012, 12:22:24 am »
1. Make a *.h file with your typedefs.
2. Reverse Engineer the Header file
3. You get a class for the header file and a nested class for each typedef
Next time start with step 3 and generate / synchronize your *.h file.
Kind regards,
Helmut
Makulik
« Reply #2 on: October 18, 2012, 12:31:28 am »
You can create a class (C-module) and place the typedefs as nested elements there. I'm not very experienced with C code generation but I think this should do the trick.
Günther
slerp
« Reply #3 on: October 18, 2012, 05:01:03 pm »
Thank you, I'll check this out :)
Kind regards
Slerp
slerp
« Reply #4 on: October 23, 2012, 05:49:29 pm »
Hi all,
checked it out and the c-module and elements as nested class works great.
Thank you
slerp
