Author Topic: Before DDL Transformation -> mark attribute as PK  (Read 2495 times)
pwyss2
« on: November 01, 2012, 08:41:21 pm »
Hy
I've a class diagram, out of which i create a ddl with transformation (for creating sql-scripts).
On each table, a primary-key is added automatically. Is there a way to mark an attribut in the class-diagram, as the one, who should be used as primary key in the ddl-transformation?
For example I've an attribute called TestNumber on my class Test, which I want as primary key in the ddl. Actually when I create the ddl, a new attribute (as primary key) calls TestId is created.
Thanks for your help,
Peter
