Author Topic: template write in attribute notes  (Read 4806 times)
MREA
« on: October 31, 2012, 11:27:01 pm »
is it possible that the template write something into the notes of the attr/operation?
e.g.
%if $comment != "" %
%else%
* No description available...\n
*\n
*/\n
%endIf%
the "No description available..." should be reverse to the model.
%opNotes%= "....." does not work, so is there perhaps a setter fct?
Support- Languages: German, English, French
Re: template write in attribute notes
« Reply #1 on: November 01, 2012, 08:39:42 am »
%if opNotes != ""%
%JAVADOC_COMMENT(genOptWrapComment)%
%else%
 * No Description available.
%endIf%
MREA
« Reply #2 on: November 05, 2012, 05:24:09 pm »
sorry I mean the else part!
else he should put "no discription available" into the model.
e.g OP1() does not have a comment.
so while generating the code "no discription available", sould be written into the model, otherwise I get a Comment in Comment in the code.
e.g
"no discription available""
« Reply #3 on: November 05, 2012, 05:37:51 pm »
Code templates can't (and should never) write to the model.
However, if you reverse engineer the generated code the desired note will be imported into the model.
MREA
« Reply #4 on: November 05, 2012, 05:43:27 pm »
mhh ok :(
so I've to tell everyone to do so
Thank you!
