Author Topic: Working with 2 Projects  (Read 4816 times)
Michel777
« on: November 06, 2012, 08:13:16 pm »
Hi, how can I work with two projects ? One for editing, one for viewing only ? Thanks, Michel
Re: Working with 2 Projects
« Reply #1 on: November 06, 2012, 08:26:20 pm »
If you don't explain your use case you can't expect a meaningful answer.
Michel777
« Reply #2 on: November 06, 2012, 08:33:08 pm »
A solution: installing the EA Lite version, opening one project with EA and the second one with the EA Lite .
Doug Blake
« Reply #3 on: November 06, 2012, 10:16:22 pm »
Open 2 instances of EA each with a different project!!
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
Makulik
« Reply #4 on: November 06, 2012, 10:28:28 pm »
No! Use the same project in this case, EA Lite will not allow viewers to modify your project, so there's no need to have an extra copy.
Günther
