Author Topic: UML Profiles  (Read 3215 times)
GDargy
UML Profiles
« on: November 08, 2012, 06:24:31 am »
Hopefully I am not duplicating an existing question.
Previously I had created a Profile Definition to add tagged values to the requirements object.  I was able to create the profile, add the tagged values and populate the tagged values with default values.  The extended "system requirement" has been used many times in the project.
There is a need to add a new tagged value to the existing "system requirement".  The new tag value was added, exported and imported into the project.  However, the default values (new and previous) are not being displayed.  Additionally, I was hoping that I could force the existing instances to utilize the new tagged value while retaining the other information.
Any insight or direction would greatly be appreciated.
g.makulik
Re: UML Profiles
« Reply #1 on: November 08, 2012, 06:30:07 am »
Lookup for 'Synchronize Tagged Values'. There were several recent threads about this topic in the forum.
Don't use 'Search the forum' but check one of the alternate options mentioned here: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1352217021
Günther
« Last Edit: November 08, 2012, 06:30:34 am by g.makulik »
