Author Topic: define "import package"  for java class  (Read 2865 times)
Piotr Rezmer
« on: November 13, 2012, 03:34:35 am »
Is there any way to store packages required by java class, so that it would generate corresponding "import java.something" entries in generated source code? I have some classes equipped with methods using arguments like java.util.Date.
kind regards
Piotr Rezmer
best regards
Piotr Rezmer
Piotr Rezmer
Re: define "import package"  for java class
« Reply #1 on: November 13, 2012, 06:02:34 am »
I think I found it.
When I right click on Class in Project Browser, then select Generate Code, it opens a dialog with memobox named "Import(s)/Header(s)".
Here I can specify:
import java.util.Date;
EA generates this import in the source code but it requires to change to "replace (overwrite) mode" instead of "synchronize with existing file".
I think that this field imports/headers should be located in Class properties.
best regards
Piotr Rezmer
