Author Topic: Parameter and Method Notes  (Read 3296 times)
Sorin
« on: April 23, 2009, 10:27:22 pm »
Hi there !
I've noticed that after updating method notes or method parameters notes, the new values are not refreshed only if I am reopening the EAP file
This is my code:
EA.Parameter param = (EA.Parameter)method.GetAt(i);
param.Notes = 'abc';
bool b = param.Update();
method.Parameters.Refresh();
method.Notes = 'cde'
method.Update();
In my app. I am not caching the objects(i.e. Methods or Parameters) so I have to repopulate all the time their values from parents (Elements and Methods).
Did anyone had similar problem ?
Re: Parameter and Method Notes
« Reply #1 on: April 25, 2009, 03:31:31 am »
There are a couple of methods - I think on the Repository object, but check Project if you don't see them - to refresh diagrams and (I think) packages. There is also a reload method for the entire model. Play around with these and you should get the results you need.
