Author Topic: Ports  (Read 2806 times)
bungle77
Ports
« on: November 23, 2012, 01:39:47 am »
I use EA since a week, but i have some problem with the ports.
I create a port X inside a block A, but if i instantiate the block A inside the block B (i create a part) i can't see the port X inside the part typed by A.
How is it possible?
Makulik
Re: Ports
« Reply #1 on: November 23, 2012, 02:57:46 am »
Check right click on block if you get the menu 'Embedded Elements' choose 'Embedded Elements' there and specify which ports should be visible.
At least for component elements this works, not sure about SysML blocks.
Günther
