Author Topic: Import of ecore UML model into EA 9.3?  (Read 4237 times)
jrueting
« on: December 07, 2012, 08:48:38 pm »
I need to import an UML model from ecore into EA 9.3.
I have tried to import the standard ecore export as XMI into EA 9.3, but this fails with the error message "unknown XMI Exporter or Version".
I have tried to import the UML converted export from ecore as XMI into EA 9.3 what also failed with the same error message.
Any idea what I can try?
Re: Import of ecore UML model into EA 9.3?
« Reply #1 on: December 07, 2012, 10:46:46 pm »
Sometimes it helps to try and fix the xmi file.
What I would do is create an xmi file from EA, and compare the header sections of both xmi file.
Then try to change the ecore xmi file so that is resembles the EA xmi file and try again.
