Author Topic: EA 8 Upgrade  (Read 2610 times)
jqureshi
EA 8 Upgrade
« on: December 14, 2012, 12:10:31 am »
Interited an EA installation, version 8 client, floating licenses on a key store service, SQL Server 2003 db back end.
I'd like to upgrade the clients to 9 or even 10 - will these clients be compatible with the existing SQL db or will I need to upgrade the schema somehow?  Also, theres probably a 2003 to 2008 SQL Server upgrade on the horizen, are there any EA considerations?
I've tried the online docs but haven't got a clear handle on this.  Any light you could shed would be greatly appreciated.
thanks
j
Re: EA 8 Upgrade
« Reply #1 on: December 19, 2012, 01:57:32 am »
AFAIR there were no major DB changes since V6/7. So you should be save. There's one issue with Requirements in V10 you will find in the release notes.
Re: EA 8 Upgrade
« Reply #2 on: December 19, 2012, 05:43:53 pm »
There's an "upgrade" script for SQL server on the website.
IIRC that script tweaks the database a bit to perform a little bit better on SQL Server 2005/2008
