Author Topic: Setting up auto counters for SysML Testcases  (Read 2643 times)
mike08
« on: January 11, 2013, 07:23:07 pm »
Hi all,
using EA 10, I'm trying to use an auto-counter for naming SysML Testcase elemets - with no luck so far. Using the standard dialog
Settings/Auto Names and Counters does not show the TestCase Element
in the Types list. Is there a way to still get auto counters to work
on Testcase Elements?
Many Thanks,
Mike
BTW: I'm using a testcase template which is based on the SysML1.3
testcase and only extends it by a number of Tags. So I think this should not interfere with the auto counter functionality.
Re: Setting up auto counters for SysML Testcases
« Reply #1 on: January 11, 2013, 11:37:46 pm »
AFAIR the SysML TestCase is based on a UseCase (pretty unsure about that but you should be able to find the base class). Try setting the counter for that base class. I guess you can't achieve more except doing complex add-in work or requesting a new feature.
