Author Topic: Deleting Images > 1 from the Image Manager  (Read 3929 times)
jfzouain
« on: January 09, 2013, 02:15:44 am »
Hi
When you select Appearance -> Select Alterante Image or Ctrl+Shift+ W on a Diagram element you get the Image Manager.
This Image Manager has more than 500 images and need to delete arround 400 of those and I don't see how to to delete more than one from here. Is there any command or script taht I can use to do this.
Thanks in advance
Best regards
Jose Zouain
Re: Deleting Images > 1 from the Image Manager
« Reply #1 on: January 09, 2013, 03:34:52 am »
You can try this:
  • Export the images from the reference data
  • Delete the contents of table t_image
  • Delete the unwanted from the export/move the wanted to a different XML
  • Re-import the reference data
Alternatively:
Repository.Execute("DELETE FROM t_image WHERE ...")if you can formulate a reasonable WHERE clause.
jfzouain
« Reply #2 on: January 12, 2013, 02:07:56 am »
Thanks Q. worked perfect.
Best regards
Jose Zouain
