Author Topic: How to  document reused elements?  (Read 3299 times)
Kamal Hammoutene
« on: January 11, 2013, 03:35:48 am »
IMHO, the following problem is a very serious one for using EA in a multi-projects - multi-products context.
I will take a very very simple example:
Create a Package called "Reusable actors" and create within this package, actors and document them in the notes section.
Now create a package called "Product A", a Use Case diagram in it and create actors and Use Cases in this Use Case diagram but also "drag and drop" actors from the "Reusable actors" package.
Now document Package A with a basic Use Case RTF template.
ONLY the actors defined in "Product A" package are listed and documented  :'(  :'(  :'(
The "reusable" actors are totally ignored.
This example appies to any element that is defined outside the documented package.
Can anybody explain to me how can I work with EA having a reuse strategy in mind?
« Last Edit: January 11, 2013, 03:59:26 am by khammoutene »
RoyC
  • Read The Help!
Re: How to  document reused elements?
« Reply #1 on: January 11, 2013, 09:04:03 am »
In the Help, read the topic:
Reporting > RTF Documents > RTF Templates > Setting Sections for Reporting > Report Elements from External Packages
Does that help you?
Best Regards, Roy
Kamal Hammoutene
« Reply #2 on: January 12, 2013, 02:31:22 am »
Does that help you?
That's exactly what I was looking for.
I didn't know that the elements that i was reusing where called "Diagram elements" in the RTF editor. I was looking for something like "External packages elements"
Also, may I suggest that the standard templates include these elements so the user can safely develop his templates on a complete report.
Again thanks for your prompt reply.
