Author Topic: Modeling Use Case Trigger and Issue  (Read 4938 times)
rnv
« on: January 15, 2013, 01:47:13 am »
This must be simple but....
I have Trigger and issues related to Use Cases. How do I properly model it in EA?
I Added Issue Element from Common tools in Use Case Diagram and created relationship but I cannot publish them in the RTF documentation. How do I do it?
What about trigger? is there a trigger element
regards,
rnv
Re: Modeling Use Case Trigger and Issue
« Reply #1 on: January 15, 2013, 03:17:24 am »
A UC does not have a trigger. It has pre-conditions.
No idea about the RTF...
« Last Edit: January 18, 2013, 02:59:38 am by qwerty »
Gary
« Reply #2 on: January 18, 2013, 02:27:21 am »
A use case has a trigger AND pre-conditions.
The pre-condition is what has to be true to enable entry into the use case. The trigger is what actually causes the use case to run.
To answer the question. Either make step 1 the trigger or create a tagged value called trigger.
PaulV
« Reply #3 on: January 19, 2013, 12:06:22 am »
You can create your own Document Template, then edit it and activate using of the Package/Element/Connector. An Issue is an Element too, it will be publisched as any other Package's Element.
