Author Topic: EA has experienced a network error and will close  (Read 5432 times)
Eric Hansen
« on: April 12, 2011, 03:16:56 am »
Hello, I am trying to connect to a Postgres 9.0 DB.  I have created the DB schema and the windows DataSource. and clicking on 'test' makes a successful connection to the DB.
However, when I try to 'connect to server' from the EA application, I get a dialog box error "Enterprise Architect has experienced a network error and will close down
Is there a log somewhere I can use to diagnose this error?  Any ideas are appreciated.
Eric-
Re: EA has experienced a network error and will cl
« Reply #1 on: April 12, 2011, 03:52:47 am »
Try searching the forum for "network error". There are quite some posts.
Eric Hansen
« Reply #2 on: April 12, 2011, 04:17:19 am »
Thanks! ...  I am new to EA and its forum and when I searched for 'network error' it was defaulting to only the last week of posts.  Once I opened up the time frame to the last year, I found a post with a solution!
The solution was to make the 'ea' user in postgres a SuperUser.  I agree with the poster that this is not a good practice.
« Reply #3 on: April 12, 2011, 07:05:26 am »
Most newbies fall into that pit with the time frame. It's absolutely pointless. Except that Sparx' server gets double tho load: no results in default + second search. The reason for that silly thing is likely that search is not database but textfile based (you guess it from search times).
Yust Another Bulletin Brake
ggacnj
« Reply #4 on: January 26, 2013, 09:11:54 am »
Hello!
I'm having the same problem.
I am trying to connect to a Postgres 9.2 Database.
I have created the DB schema and the Windows DataSource  and clicking on 'test' makes a successful connection to the DB.
As well, when I tried to 'connect to server' from the EA application version 8, I get a dialog box error
"Enterprise Architect has experienced a network error and will close down".
Help please. :-(
Thanks a lot!
GGA
Stefan Bolleininger
« Reply #5 on: January 27, 2013, 06:30:09 am »
please include the tags "inital dialog" and "odbc" into your search terms.
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1358506556
Regards
Stefan
