Author Topic: Trouble Connecting to Oracle Database via ODBC  (Read 4628 times)
bjw122
« on: February 04, 2013, 11:19:29 pm »
I'm evaluating the trial version of EA 10 as a Database Engineering tool before potentially making a purchase.
I'd like to use the "Database Engineering" --> "Import DB From ODBC..." option against my Oracle 11gR2 database.
I'm on Windows 7 x64 so I installed the "Oracle Database 11g Release 2 Client (11.2.0.1.0) for Microsoft Windows (x64)" software so that the correct ODBC drivers get installed.  After that I started the "Windows ODBC Data Source Administrator" application by running "C:\Windows\SysWOW64\odbcad32.exe" and created a data source.  When I use the option to test my connection, the test completes successfully.
See image here:
http://home.comcast.net/~bjw122/images/1.jpg
Now I start up EA 10.0 and go to "Import DB From ODBC...".  I select the "Machine Data Source" that I had defined, and I immediately get an error "Unable To Obtain Table Information".
See images here:
http://home.comcast.net/~bjw122/images/2.jpg
http://home.comcast.net/~bjw122/images/3.jpg
Oddly enough, if I go to create a new Data Source using the EA screens, I don't see my Oracle Driver listed so that could be an indication of where the underlying problem is.  See images here:
http://home.comcast.net/~bjw122/images/4.jpg
Thank you for your assistance.
« Last Edit: February 04, 2013, 11:48:50 pm by bjw122 »
Re: Trouble Connecting to Oracle Database via ODBC
« Reply #1 on: February 05, 2013, 06:49:33 pm »
EA is know to be very picky when it comes to Oracle drivers.
A search for "Oracle" in either the help or the forum (use top left search button) should yield some useful results.
bjw122
« Reply #2 on: February 07, 2013, 01:48:52 am »
Thank you.
EA Support contacted me and said:
Thanks for the note.
That the Oracle ODBC driver does not appear in EA's ODBC Data Sources suggests the 32-bit client is not installed.
EA requires 32-bit drivers.
Please refer to the Notes section on page...
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/database_engineering/importdatabaseschemafromod.html
Please uninstall the 64-bit client and install the 32-bit client. We recommend ODTwithODAC1110720 - available here ...
http://www.oracle.com/technetwork/topics/dotnet/utilsoft-086879.html
This resolved my issue.
