Author Topic: Link or Instance: how to set the option  (Read 6440 times)
markl
« on: February 06, 2013, 09:50:19 pm »
In EA v6, I used to automatically create links when dragging items such as classes onto sequence diagrams. Now in v9.3 instances are created instead without the initial choice. How do I set to 'create a link' and not 'create an instance' for this or all objects?
Re: Link or Instance: how to set the option
« Reply #1 on: February 06, 2013, 10:46:48 pm »
Ctrl-drag element to diagram, choose link, and then select Options|Autosave selection as default.
JacquesN
« Reply #2 on: February 07, 2013, 11:26:56 pm »
Geert,
I'm using EA ver 1006.
When dragging element onto sequence diagram there's no option to 'choose link' as per your instructions.
Pls advice how to set link instead of instance for the elements dragged onto sequence diagrams?
Thx
Jacques
« Reply #3 on: February 07, 2013, 11:36:04 pm »
[highlight]Ctrl-drag[/highlight] element to diagram [other then sequence diagram], choose link, and then select Options|Autosave selection as default.
I got it working here (on 10.0.1006) for sequence diagrams. I had the same issue you have.
JacquesN
« Reply #4 on: February 11, 2013, 07:10:02 pm »
Thanks Geert,
There does not seem to be any difference in behaviour between Ctrl-Drag and just Drag of element onto sequence diagram?
I'm also not sure where to find the 'Options/Autosave selection as default' setting?
Thx.
« Reply #5 on: February 11, 2013, 07:15:27 pm »
[highlight]Ctrl-drag[/highlight] element to diagram [[highlight]b][other then sequence diagram][/b][/highlight], choose link, and then select Options|Autosave selection as default.
You have to Ctrl-drag a element onto a different type of diagram (such as a class diagram) in order to get the dialog where you can set the default option.
JacquesN
« Reply #6 on: February 11, 2013, 07:58:13 pm »
Thx Geert,
I had to remove it from the initial class diagram, did the Ctrl-Drag to get the 'Paste as' menu. After setting the correct values, I could drag it to my sequence diagram. It created the link, not the instance!!  :)
Thx for your help.
Jacques
