Author Topic: Change model element type  (Read 4652 times)
cmpk
« on: February 20, 2013, 01:38:37 am »
I have a UML component model in which someone represented file input as components and I would like to change those to Artifact elements.  What's the best way to change the element type but keep all associations in the model?
Ian Mitchell
Re: Change model element type
« Reply #1 on: February 20, 2013, 02:38:07 am »
Main EA menu | Element | Advanced | Change type.
www.eaDocX.com
www.theartfulmodeller.com
« Reply #2 on: February 20, 2013, 02:38:36 am »
Try Element/Advanced/Change Type
If you have a lot of element you might think of either writing a script or running a SQL which can do the job.
[edit] Ian was faster with the first suggestion.
« Last Edit: February 20, 2013, 02:40:05 am by qwerty »
Ian Mitchell
« Reply #3 on: February 20, 2013, 03:10:29 am »
If you really do have lots, then open the package in Excel using eaDocX, then just change all the Elements Types, and (thoughtfully) read them straight back into EA.
www.eaDocX.com
« Reply #4 on: February 20, 2013, 06:00:34 pm »
or you could open up an SQL client and execute something like
update t_object set Object_Type = '<new type>'
where <criteria>
cmpk
« Reply #5 on: February 20, 2013, 11:02:09 pm »
Thanks everyone.  You've given me the clues I needed.  I managed several fixes with the manual method and then converted a whole model using the SQL route.
