Author Topic: How to compress diagram?  (Read 4384 times)
bjw122
« on: February 28, 2013, 08:48:59 am »
I have a diagram that's organized in a circle layout (see image).  It has a center focused element.  Is there an option somewhere to condense the circle so that the objects on the outside of the circle are closer to the hub?  I'm guessing there is, it would be tedious to do this manually.
See image here:
http://home.comcast.net/~bjw122/images/circle.jpg
You can't see the objects on the end of each line, but they're there -- out of view.  I want to draw them in close to the hub.
Thank you
Re: How to compress diagram?
« Reply #1 on: February 28, 2013, 09:04:25 am »
The same menu/window that gives you a circle layout allows you to select Converge.
(See http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/modeling_basics/convergediverge_layout.html)
« Last Edit: February 28, 2013, 09:05:27 am by simonm »
bjw122
« Reply #2 on: February 28, 2013, 09:13:58 am »
Truly splendid.  Thank you!
