Author Topic: Maintaining a connector relationship in a CSV file  (Read 4142 times)
andykennelly
« on: March 01, 2013, 02:31:16 am »
I drag 2 elements onto a diagram and make a connection between them. If I then delete the diagram that connection is maintained, of course..... i.e. if I view one of the elements in the traceability pane I see the connection to the other element - ALSO - if I create a new diagram and drag the elements on to it, the connection appears.
Now ..... can I retain this relationship in a CSV export, i.e. can I do an export, delete the elements in EA and then import and see the connection relationship in place???? I can't see how I'd do that with any of the Available Element Fields in the CSV Import/export specification window.
Re: Maintaining a connector relationship in a CSV
« Reply #1 on: March 01, 2013, 05:13:04 am »
For that reason they invented XMI. In that format you can export relationships. How would you do that with any csv given the fact that you can have many-to-many relationships?
