Author Topic: Activity Diagram size in RTF Report  (Read 7724 times)
rnv
« on: March 04, 2013, 11:44:44 pm »
Activity diagram in RTF report seems to extend the whole page, even if it is less than a page. Currently, in my RTF report i have Header (name of the diagram), diagram itself followed by the caption. the problem is all three published in different page becuase the diagram covers the whole page.
How can i specify that the diagram, its title and caption should appear in the same page?
regards,
rnv
manfredw
  • gaudeo ligneo!
Re: Activity Diagram size in RTF Report
« Reply #1 on: March 11, 2013, 08:54:24 pm »
Hello rnv,
I create a table where I include the diagram. This way you can limit the width of the diagram and therefore make sure the title and caption stays with it.
You can use the right click|Paragraph|Keep Together in your rtf template as well.
One more hint, make the diagram wider (horizontally) if it takes too much space in the vertical direction.
It takes a bit of fiddling to find out but eventually you'll get it sorted!  :)
Good luck!
cheers
Manfred
« Reply #2 on: March 18, 2013, 07:21:01 am »
Is this the problem you are having?
(stop zooming diagrams > 100%)
