Author Topic: MDG Technology: Tagged Value Types missing  (Read 3800 times)
Uffe
« on: May 14, 2009, 06:50:07 pm »
Hi!
I have created my first MDG Technology. It contains a set of Profiles, a couple of Transformation Templates and a single Tagged Value Type (a RefGUID type named "InstanceType").
I have deployed the MDG Technology and am using it in a different project to the one where it is defined.
The problem is that in the project where I'm using it, the "InstanceType" seems to be absent.
The type is not visible in the "Settings-UML" window, and neither are the stereotypes I've defined in my profile. But the Transformation Templates are visible under "Settings-Transformation Templates."
My MDG Technology contains only profiles, transforms and tag types. I've checked the file, and the type is definitely in there along with the rest of the stuff.
I am using the automation interface to reverse-engineer a lot of classes, and this process fails because the "InstanceType" is not available in the target project. If I add it manually, it all works.
I'm thinking I've missed a step in the deployment, but I can't think what.
Anyone else?
Cheers,
/Uffe
