Author Topic: Copying user groups and users between projects  (Read 5365 times)
andykennelly
« on: March 20, 2013, 05:59:56 pm »
I've aleady set up user groups and users (which I have then assigned to relevant user groups) in project1.eap. Is there any way I can copy/import that over to project2.eap, for which I want exactly the same security set up as for project1?
Re: Copying user groups and users between projects
« Reply #1 on: March 20, 2013, 06:30:19 pm »
Export reference data should work
Project|Model Import/Export|Export Reference Data and select "Security.
Paulus
« Reply #2 on: March 20, 2013, 06:42:35 pm »
Hi Andy,
Through export/import reference data (menu project -> model import/export ->Export reference data.
The group 'Security' contains what you need. keep in mind that this will -add- to security users/groups/permissions in the target eap  ;)
best regards,
Paulus
andykennelly
« Reply #3 on: March 20, 2013, 07:11:24 pm »
Many thanks, Geert and Paulus. That's saved me a lot of re-keying.
« Reply #4 on: March 21, 2013, 08:44:16 am »
Another option is to configure EA to use the same tables for both databases. Actually, it's a db config, but EA 10 makes it easier to do. Look for shared repository in the help.
This method has the advantage that subsequent changes to either repository will change both.
« Reply #5 on: March 21, 2013, 12:49:56 pm »
Good pointer. I haven't noticed that new feature. Will definitely look into that.
