Author Topic: HTML Generator - DAO.Fields (Item not found ...)  (Read 4106 times)
keithf
« on: March 22, 2013, 01:34:05 pm »
Hi Sparxers
I am using the HTML Generator from a specific Package node.
The Package & child SubPackages contain diagrams that reference other objects from 'external' packages (indirect and not contained within the Package).
The Generator displays the 'DAO.Fields [3265] Item not found in this collection' box with OK click required - for each instance of these referenced items and (potentially?) all connectors.
The RTF Report dialog permits greater control of these referenced items on a diagram (not directly included in the parent / child package tree) and whether to include them in the generated documentation.
Is there?
1. An ability to switch this DAO-Fields message OFF.
2. Ability to configure the HTML generation of these indirect referenced items within the HTML
thanks for your help with this
regards Keith
Re: HTML Generator - DAO.Fields (Item not found ..
« Reply #1 on: March 25, 2013, 09:02:26 am »
The error you are seeing is coming from the database. I haven't seen it before when running a HTML report.
I'd recommend sending a bug report to Sparx Systems using the link at the bottom of this page.
The first thing that they are going to ask for is the DBError.txt file from %appdata%\Sparx Systems\EA, so if you provide that with your initial report it will speed things along.
keithf
« Reply #2 on: March 25, 2013, 05:04:26 pm »
Thanks Simon
Will do - Keith
