Author Topic: Traceability Window contents in Reports  (Read 4365 times)
K N
« on: March 19, 2013, 02:20:57 am »
Hi
As we know that there is way to view the traceability of elements in EA..i.e. the Traceability Window.
Is there a way that i can get those contents in a report?
Does the Dependency & Implementation report serve the purpose? If so, how to view these reports at element level (they can be viewed at Package level).
KN
Robert Sheridan
Re: Traceability Window contents in Reports
« Reply #1 on: March 22, 2013, 08:31:37 pm »
Have you tried using the connector sections in the report?
K N
« Reply #2 on: March 23, 2013, 04:18:07 am »
Hi Robert
I did include the connector section in the report. But I am not exactly sure how to use them...When i saw the output file..there were few things repeated and it didn't made sense.
can you provide me an example?
KN
Gary@work
« Reply #3 on: March 26, 2013, 12:30:11 am »
Hi
I'm looking for the same thing.
I was thinking about trying SQL searchs but find it quite cryptic.
Does anyone know SQL/EA database sufficiently to know if this is possible?
K N
« Reply #4 on: March 26, 2013, 12:36:07 am »
Hi
What I found work around was to add the Element section. Then i added a table inside that section. Then added the Element fields - Name, Type & Realizes in the 3 columns of the table.
The only thing - as per in Traceabililty Window how we have "implements" that I am not sure how to put in it the report.
Else for now, I could do it this way.
If anyone has more on this, please do share.
