Author Topic: Oracle DB repository: setting column width to > 50  (Read 3709 times)
miku1981
« on: March 26, 2013, 12:16:12 am »
Hello forum,
we are using EA 9.2 and a database-backed repository (Oracle XE 11). We are repeatedly running into the following EA error when importing models:
OraOLEDB
ORA-12899: value too large for column "REPOUSER"."T_CONNECTOR"."BTM_MID_LABEL" (actual: 52, maximum: 50)
It appears that some columns have been created with a width of only 50 characters. I would like to increase this size. Therefore, the questions are:
1) does EA 9.2 support wider columns?
2) if "yes": how would EA 9.2 react to a DB-side increase of the values? would I need to re-create the connection?
3) if the answer to both questions is "yes": has anyone any experiences with "broadening" the columns of Oracle XE 11 *at runtime*, without dumping-and-reimporting into a new schema?
Many thanks,
MiKu
Re: Oracle DB repository: setting column width to
« Reply #1 on: March 26, 2013, 01:09:08 am »
The simple answer: just try it or send in a feature request.
If EA does not crash immediately, chances are good it will work with a wider column. AFAIR this works with tagged values. But for other columns EA fails after making it larger.
miku1981
« Reply #2 on: March 26, 2013, 01:16:56 am »
Hi querty,
I cannot try it on an empty database, and reconfiguring the existing one would incur the high risk of disturbing/interrupting some production users, so the overhead of trial-and-error-and-restore would be prohibitive.
Also, "if EA does not crash immediately", it does not mean the setup is correct, and I prefer the minimal-risk strategy.
I suspect that tagged values are mapped to columns whose names are starting with "T_"?
miku1981
« Reply #3 on: March 26, 2013, 04:11:18 am »
Well, if you want the risk free way then the suggested alternative applies: ask Sparx for a new feature.
