Author Topic: Inserting "Generated on:" date into html  (Read 9137 times)
Nick Wh
« on: March 13, 2013, 12:23:42 am »
There's lots of great html fragments that can be substituted when generating html reports.  Things like "#CREATEDATE#, "MODDATE" etc. These are for properties of EA objects.
What I want is something that will put the date the html is generated into any page - e.g. on Diagrams, Objects, etc.
It would be great if there was simply a global #TODAYDATE# or similar.  Or perhaps a guru knows how to modify the customisable Javascript that generates html, to put the date into certain places?
I've managed to put some javascript into the 'Body - Diagram' and 'Body - Object' html, but this simply gets inserted as javascript into the html, thus is evaluated every time the pages is displayed - always returning the current date.
Any hints appreciated!
Nick
philchudley
Re: Inserting "Generated on:" date into html
« Reply #1 on: March 13, 2013, 01:39:58 am »
Hi Nick
Try adding the following piece of Javascript (without the ") to the required HTML templates
[highlight]"<script type="text/javascript" >
document.write(document.lastModified);
< /script>"[/highlight]
It outputs in American format (or at least if did for me), but you may find some Javascript function to format the date.
this makes sense!
All the best
Phil
Models are great!
philchudley
« Reply #2 on: March 13, 2013, 02:02:53 am »
Hi Nick
Here's a better script with formatting into dd/mm/yyyy format
[highlight]"<script type="text/javascript">
      var generated = new Date(document.lastModified);
      var day = generated.getDate();
      var month = generated.getMonth() + 1;
      var year = generated.getFullYear();
      document.write("Generated on: " + day + '/' + (month <= 9 ? '0' + month : month) + '/' + year);
      // -->"[/highlight]
Enjoy!
All best
Phil
Models are great!
Nick Wh
« Reply #3 on: March 13, 2013, 03:23:31 am »
Ah, I had pretty much the same code, but with the line :
new Date();
instead of:
I can see what it should do - looks most promising.  Will confirm tomorrow whether it has worked.
PS I also prefer your more succint code !
Thanks Phil,
Nick
Nick Wh
« Reply #4 on: March 13, 2013, 07:39:24 pm »
Thanks Phil,
confirmed - that code works perfectly!
Added it into the 'Body - Diagram' and 'Body - Object' html templates.  This seems to cover pretty much all the web pages we use - certainly enough for support purposes - to know which version of a website people are using.
cheers,
Nick
JReed
« Reply #5 on: March 28, 2013, 02:51:11 am »
I'm looking for the same functionality (insert a "generated on" date that won't be updated automatically later), but for RTF reports.  Any suggestions?
Paulus
« Reply #6 on: March 28, 2013, 06:43:01 am »
I guess that would be the 'current date' field available from the context menu 'Insert' in the RTF template editor?
« Last Edit: March 28, 2013, 06:44:02 am by pmaessen »
JReed
« Reply #7 on: March 28, 2013, 07:50:34 am »
That's what I used in the report template to insert the value into the RTF report. but when the report is opened (in Word), the field gets updated automatically.
Paulus
« Reply #8 on: March 28, 2013, 06:29:16 pm »
I thought it didn't but you're right  :(
If you use script and the EA API to generate the RTF: i use custom data fields in the RTF template (insert->data field) and then the EA api DocumentGenerator.ReplaceField to include variable content. Works as expected.
If you use the RTF generator dialog in EA i think you need to define a project constant for the data field, but then that will have a fixed value so unless you are willing to update that every time you generate a document it won't be of much help.
If you consider scripting RTF generation: i wrote a demo on how to do that in the community resources (http://community.sparxsystems.com/resources/scripts/script-creates-rtf-document-using-documentgenerator-api).
best regards,
Paulus
« Last Edit: March 28, 2013, 06:31:43 pm by pmaessen »
