Author Topic: Customizable Port size  (Read 7157 times)
Yves C
« on: April 12, 2013, 11:38:57 pm »
I've found that now port size is customizable. Great !
I've used it and, fantastic, I've been able to change a port size. Then I've decided to add a required interface and a provided interface to the port and to increase readibility, I've tried to separate them inside the port.
But I can't find a way to do this. My interfaces are still stucked together !
Do you know if there's a way to move interfaces independently inside a resized port ? If it's not the case I can't see the use of this new feature.
Yves
Re: Customizable Port size
« Reply #1 on: April 13, 2013, 01:04:11 am »
Nobody (or at least not enough people) have asked for a feature to move the interfaces of a port. (I also think this should be possible but it's not urgent currently.)
But can you please explain how to resize a port? I was not able. Or is it just via a MDG?
Yves C
« Reply #2 on: April 13, 2013, 01:37:38 am »
In version 10 you select a port and in the contextuel menu you select "Advanced" and "Port Size Customizable".
Then you can change the port size but I don't know how you can move interfaces inside it. If you can't this feature seems useless.
Yves
« Reply #3 on: April 13, 2013, 03:01:11 am »
Ah! Thanks. Indeed very silly to introduce a resizing for a port without making the interfaces moveable. What should I say?  :-X
« Reply #4 on: April 15, 2013, 08:52:46 am »
That would be true if you considered interfaces the only thing that ports contain... The option was added because SysML users increasingly needed to use embedded ports.
« Reply #5 on: April 15, 2013, 07:06:53 pm »
But interfaces are the most "protruding" objects. I can't find an euphemism to put it in other words. I guess the reason SysMLers asked for the feature was to place interfaces more freely than it was (and is) possible. Even if not, see my first argument.
