Author Topic: Transformation template - JAVA  (Read 3041 times)
Szakika
« on: April 15, 2013, 09:11:14 pm »
i want to generate java code and i need " character. How can I escape the " character in this tempate:
[size=10]$attName=$parameter1
$propertyName=$attName
$propertyName=%REMOVE_PREFIX($propertyName,genOptPropertyPrefix)%
%if genOptGenCapitalisedProperties=="T"%
$propertyName=%CONVERT_NAME($propertyName, "camel case", "pascal case")%
%endIf%
js.key($attName).value($attName);
[/size]
Result example:
js.key("id").value(id);
Szakika
Nabil
    • View My LinkedIn Profile Here
Re: Transformation template - JAVA
« Reply #1 on: April 15, 2013, 09:36:07 pm »
use %qt%
$temp=%qt%+%attName%+%qt%
// js.key($temp).value(%attName%)
Result:
private int ID// js.key("ID").value(ID);
Nabil
