Author Topic: Serena Dimension VC  (Read 4420 times)
andyb789
Serena Dimension VC
« on: April 16, 2013, 05:56:46 pm »
Has anyone successfully used Serena Dimension VC with EA for distributed teams using local models?
I have a centralised team working with Serena Dimensions but cannot checkout to a different local .eap
Andy
Helmut Ortmann
Re: Serena Dimension VC
« Reply #1 on: April 17, 2013, 10:00:56 pm »
Hi Andy,
I don't think your problem is related to Dimension VC.
If you want to set up EA with local repositories you have to:
  •  Put packages under Version control (not the *.eap file)
  •  Checkin / checkout a by VC controlled package
  •  Distribute your *.eap file (you may put it also under VC, but it's not nessary)
  •  Make sure that in option XML Specification 'Create placeholder missing External references..' is checked
  •  Make a "Get all latest" to get the latest updates to your local *.eap file
Be aware:
- There are a lot possibilities to work with EA and or without DBMS/VC in a team.
- Often a DBMS is the easies solution to work in a team
- VC has some problems, you can handle them but it will take some time (you find a lot of discussions in this forum).
Best regards,
Helmut
