Author Topic: How to select multiple connectors?  (Read 5497 times)
DPMiddleton
« on: April 17, 2013, 06:24:12 pm »
Have been trying this for a while now: select multiple connectors and change the line style for all of the selected connectors.
On the moment, I can only select one connector at a time, so changing the connector routing style on an existing diagram can be very time consuming.
Any suggestions on how I can select multiple connectors?
Cheers,
Dave
Re: How to select multiple connectors?
« Reply #1 on: April 17, 2013, 06:38:35 pm »
The answer is simple: you can't do that.
DPMiddleton
« Reply #2 on: April 17, 2013, 07:00:21 pm »
Thanks for the reply.
I'll post it in the feature request forum instead.
Cheers,
Dave
« Reply #3 on: April 18, 2013, 12:50:18 am »
There is a "permanent" thread started by skiwi dealing with multi-select in general. Probably you should search for that and join if appropriate.
Konrad Wieland
« Reply #4 on: April 18, 2013, 01:24:11 am »
You could use EnArPowerTools for this purpose. In its first version you can apply different styles to more than one connector:
http://www.lieberlieber.com/model-engineering/enar-power-tools/features/
Cheers
Konrad
