Author Topic: Document Generation Template - Element Diagram  (Read 6670 times)
Sándor Mikó
« on: April 17, 2013, 09:39:03 pm »
Hi Community!
I would like make a template, that generate in Classdiagram subdiagrams for each class.
So each element (class) would be one little image, where he just appears.
It's possible?
Thank you for your help,
Kind regards,
Sándor
Re: Document Generation Template - Element Diagram
« Reply #1 on: April 18, 2013, 01:04:44 am »
I don't understand completely what you want, but it sounds like it needs a script to perform the required actions.
Sándor Mikó
« Reply #2 on: April 18, 2013, 03:47:58 pm »
Not only do I want to see the package diagram, but also class diagrams. The small part of package diagram which contains only the class.
« Reply #3 on: April 18, 2013, 06:00:53 pm »
Hi Sandor, you should take a minute and explain in simple words what you mean by "make a template". Please describe the use case you intend to have.
Sándor Mikó
« Reply #4 on: April 18, 2013, 06:34:37 pm »
Step by step:
Class diagram -> F8 -> templates tab -> new -> create (from basic template)
When I create documentation by these new template, I see only package in diagrams, but I want to see the separete classes too.
My question is this possible?
I attach word document, that contains 3 image.
http://mikeux.gabti.hu/EA/Dok1.doc
And one more question: How I do dinamically insert in document the generated file name?
« Last Edit: April 18, 2013, 06:37:58 pm by Mikeux »
« Reply #5 on: April 18, 2013, 06:48:46 pm »
I see. A RTF question. In that case I have to pass the ball to someone else :-)
Sándor Mikó
« Reply #6 on: April 18, 2013, 06:51:53 pm »
Yeah. Document Generation problem. (pdf,rtf)
But thank you for trying help.
SomersetGraham
« Reply #7 on: April 18, 2013, 07:13:03 pm »
Using V12
jfzouain
« Reply #8 on: April 19, 2013, 01:14:38 am »
Sandor
Took a peak at your document and yes you can insert any class before the other ones, it all depend on the Project Browser order and how you adapt your tempate from the EA basic template.
In generated documents the order of the elements is based on the order you have them in the project browser.
Which of the basic templates are you  running?
Best regards
Jose Zouain
Sándor Mikó
« Reply #9 on: April 19, 2013, 04:15:31 pm »
2nd on the list - (basic template)
I can change order and add/remove properties from template. I need part of classdiagram
Ian Mitchell
« Reply #10 on: April 19, 2013, 07:06:58 pm »
Have you tried the 'Quick Document' approach in eaDocX? Gives you LOTS more options, and simpler than RTF...
www.eaDocX.com
www.theartfulmodeller.com
Sándor Mikó
« Reply #11 on: April 19, 2013, 09:32:27 pm »
No, but i will.
