Author Topic: Switch/Case modeling in EA UML  (Read 8562 times)
HansChandra
« on: April 19, 2013, 10:43:37 pm »
Does anyone have an example of a switch-case UML implementation in te EA context?  I could not find one in the documentation or online.  I hate to implement it as a series of if..else statements.
Hans.
Re: Switch/Case modeling in EA UML
« Reply #1 on: April 19, 2013, 10:57:05 pm »
In a sequence diagram you can use an alt fragment.
What type of diagram are you trying to use?
« Reply #2 on: April 19, 2013, 11:09:09 pm »
Hans.
Both are just two syntax variants of the same semantic. Basically it boils down to a compare/jump.
HansChandra
« Reply #3 on: April 19, 2013, 11:17:20 pm »
Geert - I am using an activity diagram.  Thanks!
HansChandra
« Reply #4 on: April 19, 2013, 11:19:15 pm »
My expectation would be to see the switch /case construct in the generated code. Hope this claridfies my question a little more.
Hans.
« Reply #5 on: April 20, 2013, 12:39:16 am »
IIRC the code body is taken from the operation/behavior properties. And what is in there is up to you. I might be wrong as I'm not a code gen power user.
HansChandra
« Reply #6 on: April 20, 2013, 01:16:49 am »
I agree. I was wondering whether there is something that I could specify in the model to generate a switch/case construct ( C code) as opposed to a series of if/else statements.   I admit both end up doing the same thing once the compiler gets done with it.  I prefer switch/case in the particular code section I am modeling.
Thanks.
H.
