Author Topic: MySQL error when attempting a project transfer  (Read 2171 times)
Guillaume
    • www.umlchannel.com
« on: April 25, 2013, 04:01:14 pm »
I need to take an offline EAP copy of a project that's maintained in MySQL
However when running the project transfer, I get an error code and a short message : DB has failed
I haven't yet run a Project Integrity Check (analysis only prompts one error to fix on an orphan element) -> is it safe to run? Is there something else I should run to fix this issue?
thanks
Guillaume
Re: MySQL error when attempting a project transfer
« Reply #1 on: April 25, 2013, 04:22:49 pm »
Running integrity check is save.
Can you open the DB then "normal" way?
As a work-around: export as XMI and import into an empty EAP. Anyway if you want to copy your offline work you will likely need to transfer packages via XMI.
