Author Topic: Relationship Matrix with SQL Search  (Read 9441 times)
Maggie
« on: April 25, 2013, 08:11:34 pm »
Hello all
I have a SQL search setup that report elements depending upon a given tagged value. This works and gives the expected results.
Now I want to use this in the Relationship matrix so I set the source/target using the 'Apply Model Search' option and enter my search and search term. However, no results are seen in the relationship matrix
I would be grateful if someone could throw some light on what I might be doing wrong?
Maggie
Maggie
Re: Relationship Matrix with SQL Search
« Reply #1 on: April 25, 2013, 09:09:28 pm »
ARGHHHHH
Here is my original SQL search that does not work in the RA
select o.ea_guid as CLASSGUID, o.Object_Type as CLASSTYPE ,o.Name,o.Stereotype
from (t_object o
inner join t_objectproperties tag on o.Object_ID = tag.Object_ID)
where o.Object_Type = 'Requirement'
and tag.Property like 'Phase'
and tag.Value like '#WC#<Search Term>#WC#'
Now here is one that DOES work
select o.ea_guid [highlight]AS[/highlight] CLASSGUID, o.Object_Type as CLASSTYPE ,o.Name,o.Stereotype
from (t_object o
Spot the difference?
as replace with AS :-[ :-[ :-[
« Reply #2 on: April 25, 2013, 11:16:14 pm »
Looks like an EA bug. Especially as you did not need to replace the second AS. Or maybe you have a strange RDBMS?
markuss
« Reply #3 on: September 29, 2016, 11:09:11 pm »
I have a very similar issue (EA 12.0), however, capitalizing the AS does not help.
SELECT t_object.ea_guid AS CLASSGUID, t_object.Object_Type AS CLASSTYPE, t_object.Name, t_object.*  FROM
((((((t_object INNER JOIN t_package AS ObjectParent ON  t_object.package_id = ObjectParent.package_id)
LEFT JOIN t_package AS PackageParent1 ON (ObjectParent.Parent_ID = PackageParent1.package_id))
LEFT JOIN t_package AS PackageParent2 ON (PackageParent1.Parent_ID = PackageParent2.package_id))
LEFT JOIN t_package AS PackageParent3 ON (PackageParent2.Parent_ID = PackageParent3.package_id))
LEFT JOIN t_package AS PackageParent4 ON (PackageParent3.Parent_ID = PackageParent4.package_id))
LEFT JOIN t_package AS PackageParent5 ON (PackageParent4.Parent_ID = PackageParent5.package_id))
WHERE
The query collects particular types of requirements from different sub-packages that belong to the same project in a multi-project repository.
Same issue as for Maggie:  It returns the expected results in the SQL view. It does not populate the source/target column in the relationship matrix.
Any ideas?
Thank you very much in advance
« Reply #4 on: September 30, 2016, 06:50:51 pm »
have you tried without the
t_object.*?
I'm guessing that is the culprit.
markuss
« Reply #5 on: September 30, 2016, 11:13:33 pm »
Thank you very much for answering, Geert!
However, I just figured out that my problem was actually caused by the name I had assigned to the custom query which was "Requirement + Risk Keys for <name of my project>". After I renamed the query to "TestQuery", it works in the relationship matrix as well.
BTW: Now it also works when I include the t_object.* in the SELECT clause.
However, thanks again - you were indirectly helpful in solving my problem, for I tried your hint in a trivial query called "TestQuery" and incrementally included more and more of my acutal query till I found out that it completely works.
Markus
