Author Topic: Multiple projects in a single Oracle Repository  (Read 4502 times)
Johnb
« on: May 01, 2013, 10:57:07 pm »
I have just installed EA 10 and created an Oracle Repository for it.
I noticed when you create a new project and transfer it any existing data in the repository is overwritten.
Is there a way to have multiple projects in an Oracle Repository or am I stuck with creating a new one for each project?
« Last Edit: May 01, 2013, 11:04:51 pm by Johnb »
Robert Sheridan
Re: Multiple projects in a single Oracle Repositor
« Reply #1 on: May 01, 2013, 11:08:40 pm »
One way to do it is to have a node which contains the master elements and then separate nodes for each project which are then able to include links to the master elements.  The project nodes would then have a as a top level folder structure your standard approach, for example: Conceptual, Logical and Physical models under which in turn you would have your model views e.g Classes, Business Processes, Requirements, Components
Johnb
« Reply #2 on: May 01, 2013, 11:22:07 pm »
Thank you. I will have a play with that and see what happens :)
« Reply #3 on: May 02, 2013, 04:08:33 pm »
When you have multiple projects in .eap files, and you want to migrate them to a DBMS then you can do the biggest one with the model transfer feature, and you need to do the rest of them with xmi export/import.
And indeed you can have multiple roots for your different models.
