Author Topic: Where is the "Composite" feature?  (Read 3416 times)
lrobledano
« on: May 06, 2013, 06:50:13 pm »
Before there was an option (Advanced->MAke Composite) to make an element as a composite containing a diagram, and the option to view that content in a parent diagram.  :)
Now it is not there!   :o
I can create a diagram within an element in the project browser, but I see no way to visualize its contents in its parent diagram.  :-/
Example I have a package element in a class diagram. I want to visualize the package contents in the parent diagram class diagram.
I could do this before, where is it? what update changed this?  >:(
Re: Where is the "Composite" feature?
« Reply #1 on: May 06, 2013, 06:57:23 pm »
Right click|New Diagram|Composite Structure Diagram
Right click|New Diagram|Select Composite Diagram
is where the Make Composite feature has gone, but I'm not sure if it will do what you expect it to do.
lrobledano
« Reply #2 on: May 06, 2013, 08:16:56 pm »
Thanks Geert.
Neither from the browser nor from the diagram: right click and nothing, there is no "New Diagram", less to say "Composite Structure Diagram or Select Composite Diagram".
Only from the project browser I did "Add->Add Diagram" but no chance from the Diagram view or the option of making this diagram visible.
What version do you have?
« Reply #3 on: May 06, 2013, 08:28:48 pm »
Geert is talking of V10. From the diagram you have the New Diagram (which also is used to remove the composition :o) entry.
