Author Topic: Howto properly document element relations (RTF)  (Read 3832 times)
marcel_str
« on: May 02, 2013, 11:55:10 pm »
I would like to document all links to an element, but not document the element itself. This is the way I'm trying:
[highlight]element >[/highlight]
Element {Element.Name} targets Element: [highlight]connector >[/highlight][highlight]target >element >[/highlight]{Element.Name}
[highlight]< element< target< connector[/highlight]
[highlight]< element[/highlight]
Problem here is that the RTF generator just takes a connector which is attached to the element, and documents its source or target (depending on the section chosen). That way you always end-up with the element being linked to... itself.
To clarify:
Element a (source) has an association with element B (target). Documenting all connector targets of elements A and B ends up nicely telling:
Element A targets: Element B
But for Element B it says:
Element B targets: Element B
And that's not what I want. Element B doesn't target anything, it only has a connector connected with it's target point to it.
Hope you can help
Ian Mitchell
Re: Howto properly document element relations (RTF
« Reply #1 on: May 07, 2013, 11:20:29 pm »
I think with eaDocX you could create a profile for Element_A (type) so that it doesn't print any of its own attributes, just those of the relationships it has with other Element_Bs. Make sure you specify the direction of the connector as 'Normal' i.e. source-> target.
www.eaDocX.com
www.theartfulmodeller.com
