Author Topic: [Help] add images into Requirement element for RTF  (Read 7787 times)
miro
« on: May 08, 2013, 12:09:06 am »
hello,
I would like to add images to a Requirement Element and get the images displayed when the RFT document is generated.
My goal is to have an image rendered under the requirement element in the RTF document.
I have tried to add a Diagram to the Requirement Element and add an image in the Diagram, but unfortunately diagrams that are sub childs of Element's are not rendered in the RTF. I have tried to tweak with options, but unfortunately I have not found any solution to my problem.
Any solution is valid for me, in order that images that belongs to requirements are displayed under their requirement in the RTF document.
can you please help me?
I'm using EA 10.0.1007 professional Edition.
Thank you
Dermot
Re: [Help] add images into Requirement element for
« Reply #1 on: May 08, 2013, 02:23:12 pm »
A  good option for this is to use the Requirement-Element's Linked Document. Add  your image to this and then include in the RTF template the section: Element | Linked Document (leave blank).
This will report the image and any text associated with it.
In terms of the Child diagram - this can still be rendered in the report - but you need the Section: Element | Diagram - enabled.
miro
« Reply #2 on: May 08, 2013, 05:52:05 pm »
Thank you very much.
the  Element | Linked Document  solution works well! It's also possible to embed the images in the document, and that's great ;D
