Author Topic: SQLRepository  (Read 2820 times)
Michael
SQLRepository
« on: May 14, 2013, 12:42:57 am »
are there   packages for SQLApi library to deal with this method
public bool AllowDuplicates
   get
       Throw new NotImplementedException();
   set
« Last Edit: May 14, 2013, 12:44:02 am by MichaelRahn »
Re: SQLRepository
« Reply #1 on: May 14, 2013, 04:28:04 pm »
Do you mean you need the implementation for the property AllowDuplicates for EAAttribute.cs
I guess if it isn't there you'll need to write it yourself. But it can't be that hard. There a column in the t_Attribute table called AllowDuplicates. I guess all you need to do is set it to 0 or 1.
If I were you I would try this as an implementation of the getter:
        get
                return HelperMethods.getXMLNodeContentFromSQLQueryString(xmlAttributeEntry, "AllowDuplicates")[0];
I haven't seen any implementations of setter methods, but I guess they should be in there somewhere.
