Author Topic: Viewpoint Spreadsheet  (Read 12422 times)
Viking
« on: May 16, 2013, 09:26:57 pm »
hopefully the category is correct.
A simple question: we need a Spreadsheet viewpoint for our Enterprise Architecture Mangement. It should be similar to a simple speradsheet in Excel. It should support lines and rows, filters (autofilter), and colors. That's all.
Is there something like that available in EA? If not, is it possible respectively recommended to integrate Excel via OLE / ActiveX ?
Best regards
Viki
Ian Mitchell
Re: Viewpoint Spreadsheet
« Reply #1 on: May 16, 2013, 10:02:29 pm »
the eaDocX (Corporate Edition) Extension integrates Excel closely with EA.
If you mean that a Viewpoint is a diagram  of some aspect of your model, then just open the diagram's contents as an eaDocX Excel spreadsheet.
www.eaDocX.com
www.theartfulmodeller.com
Viking
« Reply #2 on: May 16, 2013, 10:23:47 pm »
Many thanks. Is there a video available?
Where is the advantage between integrating Excel (if it is possible) and your solution?
For my opinion my request requires very simple features. I cannot imagine that this is not supported by EA. Am I wrong?
Ian Mitchell
« Reply #3 on: May 16, 2013, 10:25:46 pm »
The only support for Excel in EA is to read- and write- CSV files.
www.eaDocX.com
Viking
« Reply #4 on: May 16, 2013, 10:44:06 pm »
I understand.
Could you also answer the other questions, please?
Ian Mitchell
« Reply #5 on: May 16, 2013, 11:09:34 pm »
which specifically ?
www.eaDocX.com
Viking
« Reply #6 on: May 16, 2013, 11:39:54 pm »
(1) Is there a video available (e.g. on YouTube)?
(2) Where is (would be) the advantage between integrating Excel (if it is possible) and your solution?
Dermot
« Reply #7 on: May 17, 2013, 03:48:09 pm »
At present there is option that you can use in an Element's Linked Document. You can try the context menu option: Insert | OLE Object and insert an Excel spreadhsheet.
This has it's limitation in that the view in document is limitted, but you can repoen it to view the full sheet.
« Last Edit: May 17, 2013, 03:49:04 pm by Dermot »
Ian Mitchell
« Reply #8 on: May 17, 2013, 05:15:25 pm »
@Viking
We have a video guide to eaDocX & Excel at  http://www.eadocx.com/index.php?option=com_content&view=article&layout=edit&id=356.
..and on the web-help at http://www.eadocx.com/help/index.html?eadocx_and_excel.htm
They should get you started.
There's also now a white paper on Power Editing with Excel at http://www.eadocx.com/web-downloads/white-papers/category/17-working-with-ea-and-eadocx
These should help you decide if you want to use the eaDocX approach, or the one outlined by Dermot.
www.eaDocX.com
Stefan Bolleininger
« Reply #9 on: May 17, 2013, 05:38:24 pm »
Sorry Dermot but the internal OLE Support really, really sucks.
Another option: - Write an Addin, which
1. Saves your linked document to the temp path package.element.savelinkeddocument(file)
2. Open in your standard programm according to windows. process.Start(file)
3. Save it there and close your windows programm
4. reload the element package.element.loadlinkeddocument(file)
That's all to do :-)
Regards
Stefan
Viking
« Reply #10 on: May 22, 2013, 05:37:52 pm »
@Ian
Many thanks. I did not know this product. Seems to adress also other issues we have, We will have a closer look.
@Viking
Viking
« Reply #11 on: May 22, 2013, 05:38:48 pm »
Many thanks. This is what I was looking for.
Viking
« Reply #12 on: May 22, 2013, 05:40:58 pm »
@Stefan: Many thanks for sharing your experiences. Very helpful.
Regards
Stefan
