Author Topic: EA repository does not open - need resolution ASAP  (Read 4459 times)
K N
« on: May 23, 2013, 01:01:10 am »
Hi
I have a EA repository created with MySQL server.
when i open the repository through EA, it gets connected to the repository (which i know with the name that comes on the top of the EA screen), but the cursor goes round and round around the Open Project dialog box...
what could be the reason behind it?
Need to know the resolution ASAP, plzzz
KN
Re: EA repository does not open - need resolution
« Reply #1 on: May 23, 2013, 02:09:31 am »
Have you ever used the repo or is it a fresh one?
Helmut Ortmann
« Reply #2 on: May 23, 2013, 05:22:49 am »
Make sure:
- creation script for MySQL has successfully run
- you have the correct rights
- you have transfered a model to your MySQL DB
  Tools, Data Management, Project Transfer
  (you may use one empty repository (*.eap file with no or few content)
- You can check with MySQL query
   select * from t_object
Kind regards,
Helmut
« Reply #3 on: May 23, 2013, 03:49:57 pm »
And don't forget security.
There are often issues with DBMS repositories because the user doesn't have enough rights on the database.
I would suggest to grant all possible right to begin with, and then take rights away until it stops working.
K N
« Reply #4 on: May 30, 2013, 11:47:23 pm »
You can say it was Magic or something but the repository is working now...before i could do any of the steps that were suggested.
Thanks everyone!!!
