Author Topic: Realization Connector  (Read 4295 times)
Prateek
« on: June 04, 2013, 07:40:40 pm »
Hi All,
I'd like to create a realization connector between two component elements or between elements component and class ... There seems to be no direct option to create the said connector for the mentioned elements types. What i do is, create a conenctor ( chosoe one b/w 'trace', 'information flow' and 'depedency' which are the only options available ) and then change the type to 'realization'.  Pl. let me know if there is any other way to create the 'realization' connector b/w element types - component and b/w component and class...
Thanks..
Thelonius
  • I think. Therefore I get paid.
Re: Realization Connector
« Reply #1 on: June 04, 2013, 08:09:14 pm »
Would using the Realisation connector from ArchiMate be possible, I wonder?
« Reply #2 on: June 04, 2013, 08:20:10 pm »
I had no problem to select the Realization connector from the toolbox and draw it between components.
Prateek
« Reply #3 on: June 04, 2013, 10:46:56 pm »
Thanks qwerty... it is working that way !
Graham_Moir
« Reply #4 on: June 06, 2013, 07:12:15 pm »
Yes the issue is using the quicklinker and its associated context sensitive right-click menu which only gives you a subset of connector options
