Author Topic: Arc and arcto in shape script  (Read 3991 times)
MichelV
« on: June 17, 2013, 05:46:28 pm »
I created a new profile with a new stereotype and I'm now trying to create a shape using shape script, as described on http://www.sparxsystems.com/enterprise_architect_user_guide/10/extending_uml_models/add_shape_scripts_to_uml_profi.html
I now have the following:
shape main
  moveto(85,0);
  lineto(15,0);
  arc(0,0,30,60,15,0,15,60);
  moveto(15,60);
  lineto(85,60);
  arc(70,0,100,60,85,60,85,0);
Instead of using "arc" I would like to use arcto so I can use startpath(), endpath() and fill the shape using fillandstrokepath(). But it seems that arcto results in a completely different arc than the arc function.
Why does
moveto(15,0);
arcto(0,0,30,60,15,0,15,60);
result in a completely different arc line than:
Who can help me rewriting my shape script using arcto instead of arc, so I can have a filled shape?
Re: Arc and arcto in shape script
« Reply #1 on: June 18, 2013, 08:57:34 am »
It looks like an issue with the preview window.
If I put in your script and replace arc with arcto it looks as you would expect on a diagram.
MichelV
« Reply #2 on: June 18, 2013, 04:30:18 pm »
Thanks Simon. You're absolutely right. It is indeed only a problem with the preview window of the Shape Editor. If I use the new stereotype in a diagram the shape looks fine. Good to know!
