Author Topic: Shortcut Required  (Read 4619 times)
Prateek
Shortcut Required
« on: June 20, 2013, 09:06:45 pm »
Hi All,
We are building upon a model wherin we require a combination of connectors i.e some are direct and the rest are Line Stlye-->Tree Style Horizontal. We have some 300-400 connectors per diagram and we have number of such diagrams to make. So we wanted to know if there is any shortcut for Line Style--> tree style horizontal also like we have a shortcut(Ctrl+Shift+D) for direct connections.
Sadly,the tool also does not have the option for selecting multiple connectors. :(
Re: Shortcut Required
« Reply #1 on: June 20, 2013, 10:50:51 pm »
No, there's not.
Helmut Ortmann
« Reply #2 on: June 20, 2013, 11:47:09 pm »
Hallo,
if you have rules for your line-types you may write an addin.
I made a script where I select Elements and say what line style I want to have. Then the Addin change the line style of all in/out-coming visible lines according to the selected linestyle.
The gist is: You need to have rules that you can enforce by the addin.
The ingredients for such a script are:
- selected elements
- selected connector (only one)
- stereotypes
- etc.
Best regards,
Helmut
Prateek
« Reply #3 on: June 21, 2013, 01:29:09 am »
Thanx Helmut.
Can you please tell what is the name of that addin and from where can I get it.
Makulik
« Reply #4 on: June 21, 2013, 01:45:36 am »
Those who can read have a clear advantage ...
« Last Edit: June 21, 2013, 01:46:01 am by Makulik »
g.makulik
« Reply #5 on: June 21, 2013, 04:43:29 am »
Instead of an AddIn an automation script might also be suitable (sufficient) for this task once or repeatedly for the already existing connectors.
[edit]
Just to figure out the intend of my previous reply it should have been looking like this:
Thanx Helmut.
[/edit]
« Last Edit: June 21, 2013, 05:47:56 am by g.makulik »
Helmut Ortmann
« Reply #6 on: June 21, 2013, 04:48:00 am »
I have implemented a c# Addin with my own rules. They are simple:
  • Select one or more Elements on the diagram
  • Choose the line-type in the addin (all standard line types without shortcut)
The Addin will apply the line-style to all visible connections of the selected elements.
If you are interested I send you the source code of the addin without warranty and free of charge. Ok in fact you will get a lot more functions which you could use or delete. In effect: Free of copyright.
A deployment project WIX is included.
You may use it as a starting point for your own Addin.
Have a look on LieberLieber. If I remember correctly they also have something.
Kind regards,
Helmut
Helmut Ortmann
« Reply #7 on: June 21, 2013, 04:53:12 am »
a script solution as proposed by g.makulik is also smart. The advantages of a script solution are:
- Easier to develop
- Faster in execution
Kind regards,
Helmut
