Author Topic: Executing SQL update  (Read 4963 times)
novikovigor
« on: June 21, 2013, 02:04:07 am »
I can execute SQL select with "Model Search" tool.
But how can I execute update and insert commands in EA? Is there fast way to do it?
Re: Executing SQL update
« Reply #1 on: June 21, 2013, 04:02:35 pm »
You can't with the model search.
If you are working with a .eap file you can open that in MS Access to execute update queries, or just use any other generic SQL client.
If you are working on a dbms repository you best use the client for that type of database.
You could also write a script or add-in and use the "hidden" operation Repository.Execute(SQLString) to execute your update queries.
Just be really really careful. It's quite easy to completely destroy your model using SQL ;D
novikovigor
« Reply #2 on: June 21, 2013, 08:05:47 pm »
Thank you, Geert! I'll use MS Access.
